my krap arrives in 10 hours
what settings do i need to overclock to 4.5-4.6sh
will tinker with the fine'r details later lol just need a idea where to start
will be dumping my h100igtx on it so coolings not a issue
heres the parts i got
GIGABYTE Z170X-GAMING 5 LGA
Corsair Vengeance Lpx 16GB 2X8GB DDR4 3200MHZ
INTEL® CORE™ I5-6600K 3.50GHZ
gonna beat gta5 again as my test to see how much better this is compared to my 9590 lol
https://linustechtips.com/topic/596717-i5-6600k-overclock-settings/
Give it 1.3-1.375v, and change the multiplier to 45 or 46.
Luck. That's all you need.
  1. Start putting the multiplier at stock.
  2. Put voltage on Fixed Mode and input 1.25v
  3. Stress test it for about 20min and see how hot it gets. If lower than 80, up voltage a notch and repeat, until you find your max voltage. That's what we are going to work with.
  4. Put your multiplier at your desired value. Stress test it for stability. If it works, it works. If it doesn't, bump it down till it works.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
1 minute ago, kronickiller said:
whats max temp for the processor
V
2 minutes ago, Imakuni said:
80
You can actually go further, but that's a good baseline.
a question like that makes me worry about your knowledge in overclocking
80 is dam lol
thought my 9590 was hot lol
my fx chip rarely hits 50 lol
AMD's CPUs have a lower limit than Intel's, due to crappy sensor positioning.
25 minutes ago, kronickiller said:
well started small 1st try seems stable
4.5 at 1.37v staying under 50c
Congratz on not following the instructions.
13 minutes ago, kronickiller said:
and xmp sends it into a shit fit lol
If your XMP changes the BCLK, that would be the reason. You'd have to dial down the multipliers for CPU and cache to match the new base.
Also, frequencies above 3000mhz start to depend not only on the RAM, but also on your board and CPU's IMC. Sometimes, you can't get it function, even if your kits are rated for 3200.
There's also a possibility that it wasn't the RAM that caused problems, but rather your CPU OC not being stable in the first place. Which is my bet; you couldn't have possibility verified it properly, not within the time frame of these posts.
hmm i kicked the xmp profile multiplier down to 1 and it booted up no problems
will run stress test for a hour or so see if it dies
will let it run overnight if it doesnt krap out
i can live with 3100mhz lol
have my cooler on silent mode it never ramps up to jet engine mode anymore so nice and quiet lol
freakin 9590 kept that thing on aircraft carrier mode gaming
thanx for the help
brought it to 1.38 for 4.5ghz and my ram 3100mhz and my video card is sitting pretty with its 1130/1400 overclock with no issues
my old fx chip kept my case pretty warm wasnt able to ever keep the overclock for the card that high lol
just gave it the old witcher 3 tempature test lol card is staying arround 85 which is nice, always had to put the card at stock b4
now to find some poor fool to buy my 9590 mb and ram lol
maybe i will try for a higher overclock when i bored but this is good enough for now
