Well, by the end of this year, I'll be upgrading my motherboard, CPU, RAM, Case, and cooler. I have 2 sets of options here. Option 1:http://pcpartpicker.com/user/Memer-Senpai/saved/zyqD4D
And Option 2: https://pcpartpicker.com/user/Memer-Senpai/saved/NGnZxr
They are two different architectures with different advantages. I don't know which to choose! Someone help me make a decision by Pros and cons etc. Thanks!
https://linustechtips.com/topic/596670-new-parts/
Just now, Sena17 said:
Well, by the end of this year, I'll be upgrading...
Then come back here once you are ready to buy. By then, it's likely that Zen (and possibly even Kaby Lake) will be available. Can't really plan THAT much in advance.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/596670-new-parts/#findComment-7750918
I'm not planning on doing the latest and greatest when it comes out. I'm planning on the latest and greatest of the last two generations and leave it that way for a few years.
https://linustechtips.com/topic/596670-new-parts/#findComment-7750922
Right. So if Kaby / Zen offers a better price to performance ratio, you are still willing to get older hardware? Sounds dumb by me, but suit yourself...
https://linustechtips.com/topic/596670-new-parts/#findComment-7750927
If it has a better price to performance ratio, then, logically, the previous generations will drop in price no?
https://linustechtips.com/topic/596670-new-parts/#findComment-7750929
Nope. Not at all. Stuff like this doesn't drop in price (unless you go hunt the used market).
https://linustechtips.com/topic/596670-new-parts/#findComment-7750931
Okay. Either way. I'm not future proofing. I just need to know what's a better idea. Using what I gave you to work with, can you tell me what the pros and cons would be? Keep in mind my actual system so far would add parts on like ram etc.
https://linustechtips.com/topic/596670-new-parts/#findComment-7750935
I'm... not sure. Gimme 5 or 6 months for me to do my research, before I can give you an adequate answer.
https://linustechtips.com/topic/596670-new-parts/#findComment-7750946
so basically, 6700k + ddr4 vs i7 4790k + ddr3
i would pick the 6700K, reasons:
1) ddr4
2) higher efficiency
3) higher single core performance, and also multithreaded
but yea, always decide on a pc part about 1 month or 1 week before you buy it if possible
you can save up for the approximate amount you'll need and decide on parts near the day of purchase
as newer technology might be available and the best value might not be on these parts anymore
but it's your money so we're not obligated to tell you how to spend it tbh lol
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/596670-new-parts/#findComment-7750993
1) ddr4
thanks for not being a sarcastic jerk. Means a lot.
https://linustechtips.com/topic/596670-new-parts/#findComment-7751005
sarcastic as he is, he makes a good point for what you should do
which is probably what almost everyone who knows tech will tell you to do
https://linustechtips.com/topic/596670-new-parts/#findComment-7751011
