Recently i bought a bottle pastel red concentrate from EK
I'd heard of many saying that it had a pinkish tint to it, but in pictures it didn't look as bad as it does for me, it looks like a bright pink
While the pink does look pretty cool, it doesnt really fit in with the rest of my build.
I have no idea on how to make the pastel darker, as i have some blood red dye, yet on the bottle it says not to mix the pastel coolant with anything else.
Any ideas?
https://linustechtips.com/topic/596563-ek-ekoolant-pastel-red-problems/
Is the dye from Mayhems by chance? If so then you should be able to mix it with the Pastel, if you're not sure you can always email Mayhems to ask.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Any ideas?
You can dye pastel to make it darker but if it's changing color on you the fluid may be degrading. As mentioned mayhems makes dyes that works with the pastel series as they are partnered with EKWB.
1 minute ago, Any Random Name said:
so if i have a blue mayhems dye, I can put a few drops in to make it look darker, and no problems will occur?
Yes you could but blue might make it have a slight purple tinge.
