6 minutes ago, Nicko_barbeque said:
Hey guys im doing an assignment on watercooling and i need to know all the different brands... I have found EK (obviously) and XSPC. Any others you can think of?
Thanks a heap.
Some of the major ones, there are quite a few others that specialize only in one aspect of watercooling:
EKWB
XSPC
Alphacool
Swiftech
Bitspower (fittings mainly)
Aquacomputer
https://linustechtips.com/topic/596562-assesment-help/#findComment-7749975
EKWB
XSPC
Alphacool
Swiftech
Aquacomputer
Thanks heap for that... If you could remember any of the smaller  brands that specialise in certain areas without going to too much trouble that would be great but if not then thanks all the same. Really helpful :-)
https://linustechtips.com/topic/596562-assesment-help/#findComment-7749985
Some of the larger specialized ones would be:
Mayhems (fluids)
Hardwarelabs (rads)
primochill (tubing and fittings)
Koolance
Phyoba
https://linustechtips.com/topic/596562-assesment-help/#findComment-7750013
Thanks a heap.
What assessment requires knowing Watercooling brands?
https://linustechtips.com/topic/596562-assesment-help/#findComment-7751412
