Hello, I have a Corsair Obsidian Series 900D and I want some LED strips to make it look... Pretty. I was wondering if magnetic strips would work inside my case and if so which ones do I get and they have to be rgb and 4 pin controlled because I have an NZXT HUE that I would like to use with the led strips any recommendations... If you don't know any magnetic ones would you mind recommending me some adhesive ones. Thanks in advance... :)
https://linustechtips.com/topic/596549-led-strips/
For the original Hue you can use any standard RGB 4 pin LED's but any premade solutions come as a kit with controllers like ones from Cable Mods or any other manufacture. You could get a roll of SMD5050 LED's and hook them up if you want to DIY it.
-Moved to Modding Section-
https://linustechtips.com/topic/596549-led-strips/#findComment-7749897
