Hey i need some help here so someone please give me some advice. I am looking for a gtx 980 for my rig but I need it to have an available water block for that model. I would buy a reference but at that cost I might as well buy a non reference 980ti. I was looking at the msi 4g card but I don't know if there is a water block for it. If you can help that would be great. Also please put a link to the water block and graphics card you recommend. thank you so much.
https://linustechtips.com/topic/596429-help-please/
Do you not want to wait for the GTX 1080? It is so much better for the same price. Twice (Correct me if I am wrong) the performance of a Titan x, same price as a 980ti. You might have to wait a few months but it would be worth it.
ERROR: VAR_TRAINOFTHOUGHT RETURN CHAR(MISSING)
RESTART  BRAINTHOUGHTS_MAJORGOOB.EXE?
Y                             N
https://linustechtips.com/topic/596429-help-please/#findComment-7748594
I was looking more for a gtx 980. Also about how much will the 1080 or the 1070 cost
https://linustechtips.com/topic/596429-help-please/#findComment-7748731
Correction: 2x better in VR only. Overall performance for acctuall games is more like 15-30%. Depends on how much you OC.
1080 will cost around 600$
1070 will cost around 380$
4 minutes ago, littlemanbigdreams said:
do you know the performance of the 1070
Nope we don't know yet, but it should be around titan x performance. Probbably a bit less, but we don't know anything for sure yet.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/596429-help-please/#findComment-7748776
