Hi all - looking to get a new PSU as mine is over 5 years old and out of warranty, plus its not modular and i'm putting my PC on a wallmount so i'd like it to be a bit prettier :)
My rig;
Mobo - Asus Z97 Pro
GPU - Asus Strix 970
CPU - i7 4790k
RAM - 2x4GB DDR3 1600mhz
Watercooled with XSPC raystorm CPU block and EK GPU block, monsta 360mm rad (80mm thick) and 6 x noctua nf-f12 fans.
I've looked at the EVGA G2 range, either the 650 or 750. Would the 650 be good for the build? Its 15mm shorter which is handy for space and £25 cheaper than the 750.
Any other suggestions? I would like it to be 80+ gold or platinum, modular, have a zero-noise fan option, and a 5+ year warranty.
Cheers,
Dan
https://linustechtips.com/topic/596407-another-psu-help-thread/
Corsair RM650. Zero fan option. Shorter (ish)
Great looking flat black cables instead of those weird sleeved EVGA ones.
I've had several RM550s, RM650s, and RM850s for various builds for friends and I've even used them in a few workstation builds.
Excellent units.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748283
My rig;
Mobo - Asus Z97 Pro
CPU - i7 4790k
Cheers,
Dan
RMi 650
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748294
Excellent units.
The RMx is a much better unit for less money.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748303
1 minute ago, BigDan1190 said:
Whats the difference between RMx and RMi? On amazon the RMi is actually cheaper. I thought the "i" just meant you can connect it to USB and use the software.
It seems to be that the RMx has the worse cables. The RMi has the same cables as the standard RM
and the I adds that USB functionality.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748321
The RMi has the better fan and the Corsair link function. You can also change between a single rail and multi rail.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748327
3 minutes ago, ShadyHost said:
I checked and the RMx has those gross sleeved cables. Standard RM has the flat black individually coated ones.
Flat black cables doesn't make it perform any better though. I personally prefer round cables as they are easier to manipulate when doing cable management.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748381
We're talking about like $5 here. I'd rather have the flat black ones haha.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748405
But the RM is kinda crap for what you pay for it. Anyways, the EVGA G2 sounds like what you're looking for.
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7748489
Thanks everyone. I read that the G2 is slightly better in terms of performance, but come on this is a PSU... went for the Corsair as its much nicer looking and i know/trust the brand more. Got myself an RM650i and 16GB of corsair 2400mhz ram ordered (my 8GB 1600mhz set is getting VERY tired).
Thanks again!
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7749175
The RMi and RMx used the same Type 4 cables. Both of which has blacked sleeved 24-pin, 4+4 pin, and 6/8pin cables, while the rest of the cables are flat black ribbon cables.
The original RM has all flat cables and based off of the older Type 3 cables (lack of v.sense wires and capacitors).
https://linustechtips.com/topic/596407-another-psu-help-thread/#findComment-7749286
