Heres the build http://pcpartpicker.com/user/OnionRings/saved/d7Zscf
I think the PSU isn't bad, highly rated, enough watts for what I need, not expensive.
Case though, need massive help. Doesn't have to " look " pretty, long as it fits everything with room for expansion im happy, good cooling, air flow, fan sockets for future fans, but not too expensive. Sturdy is key for me here with the case, don't want it breaking or bending especially since it kinda ya know houses all my expensive components.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/596344-help-with-case-and-psu/
13 minutes ago, OnionRings said:
its ok but the quality isnt brilliant. this one is 5$ more but better quality:
http://pcpartpicker.com/part/seasonic-power-supply-s12ii430b
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7747795
How do you know the quality if it has no reviews? Thats all im wondering cus everyone links me parts with no reviews, even my mobo has none.
CPU
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7747798
The sea sonic is also not modular.
CPU
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7747803
everybody who knows much about psu's on this forum says that seasonic and antec have better quality because they use japanese capacitors instead of cheap chinese ones. maybe there is other stuff too but thats how it is.
modularity doesnt mean quality
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7747809
I know it doesn't mean quality, but I would like semi mod for better cable control and air flow
CPU
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7747812
If you're not putting a GPU in the system then that Corsair CX430M is fine.
https://linustechtips.com/topic/596344-help-with-case-and-psu/#findComment-7748514
