I have an hp 15 notebook pc with an intel i3 5010 dual core processor. I want to play games on it since it is a transportable object. How can I boost its performance. I have already gone through startup programs. De cluttering re partitioning, and a few little things. How can I get it to stop stuttering in games like cod. I have 1 2 gigabyte ram card and 1 4 gigabyte ram card at 1600 MHz
https://linustechtips.com/topic/596077-what-is-possible/
You really can't, the graphics card in your laptop is just too weak, if you're considering buying a new computer, i advice you to ask us for help building you a gaming computer (doesn't have to be expensive (400$ or less)) and not to buy laptops if you want to game on a budget
https://linustechtips.com/topic/596077-what-is-possible/#findComment-7745277
You can't do much... This is a great sub 300 build though
http://pcpartpicker.com/p/898wt6
"AMD is bringing DDR5 to the mainstream with their all new FX 8450 and FX 9690 Zen processors. Check out the link in the video description to learn more."
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
    16gb Corsair Vengeance DDR3-1600
  • GPU
  • CHANGING
  • Case
  • BitFenix Comrade Window Black/
  • Corsair 250D
  • Storage
    Hectron X1 60gb SSD "The China", Hitachi 500gb 7200rpm
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
    AULA F2012 Mechanical
https://linustechtips.com/topic/596077-what-is-possible/#findComment-7745310
Make sure all the graphics settings in game are turned to minimum. Other than that you pretty much need to buy something else.
Look at my systems:
My main testing/gaming system "Bitlo" is an upgraded HP Pavilion p6710f:
AMD Athlon II X4 640 undervolted to 1.225v vcore @3.00GHz, with additional undevolts for each P-state.
Stock AMD cooler- with the undervolt that's all I actually need
8GB PNY DDR3
Zotac GTX 560 Ti, 880MHz core & 2360MHz mem at stock voltage, has been delidded and repasted, plan on strapping an AIO on to overcome current temp issues
EVGA 500W PSU
120GB Toshiba Q300 SSD
1TB Seagate HDD
Every day carry: Toshiba Satellite L655-S5150. Pentium P6200 @2.13GHz, 4GB RAM.
Black themed workstation I'm working on:
Xeon E5-2670 (SR0KX)
Cooler Master Hyper T4
ASRock X79 Extreme4
16GB (2x8) Adata XPG DDR3
Gigabyte R9 290 OC Edition
Sound Blaster Audigy 2 ZS
Dell XPS 630i 750W PSU
OCZ Vertex 3 120GB SSD
Hitachi Ultrastar 1TB HDD
Diablotek EVO ATX Midtower case
https://linustechtips.com/topic/596077-what-is-possible/#findComment-7745326
