Recording quality question
Solved by I am an SSD,
Just now, GamerGuyEbby said:I recorded a video of gameplay for youtube and I used XSplit gamecaster (free version). It said it was recording in 720p then I edited it in 720p, exported it as a .avi file, then converted it to .mp4, then to youtube and it is 360p. How can I make show up in 720p?
Are you sure it isnt still processing HD?
Also check the video file you are uploading to see quality..maybe something was unchecked during exporting
