This video is in 4K at 60 fps! (even though it would be the same at 1 fps)
What i've bought:
I've bought the i3-4160, 1x8GB HyperX Fury Red RAM Module, the GA-H81M-S1 rev 2.1 motherboard, the NOX Coolbay RX case and i still have to buy the case and the power supply. I will be using the current hard drive from my old 2008 computer (1 TB).
I MAY GET THE R7 370 INSTEAD OF THE GTX 950!
Uses:
  • Playing Cities Skylines
  • Browsing the web a lot!
  • And playing some light games.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/595778-my-current-build/
Uh oh.
Cities Skylines is a massive CPU game. The i3 will tank fps down to 20 ish if you build a city over 80k people (I tell you from experience). That forced me to have to pause the simulation every time I wanted to make a change, until the game became clearly unplayable at 120k city population.
If you can still return the i3 and get something bigger, I recommend it. Look for an i5 4690 (uses same motherboards).
Also AMD will have great offerings for $100-150 with their new generation, or so we hear!
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742486
33 minutes ago, NunoLava1998 said:
Some PSU
Get this CX from corsair. Don't get the old ones with a green sticker. It's $50 after a mail-in rebate over at micro center. http://pcpartpicker.com/part/corsair-power-supply-cp9020101na
34 minutes ago, NunoLava1998 said:
Some Case
This is where you can save some buck and upgrade later. There's a nice case you can get for $20 after MIR if you buy it soon. http://www.newegg.com/Product/Product.aspx?Item=N82E16811124165
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742520
I got my case for 30-40 euros. Pretty cheap and full of features.
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742776
That's pretty good.
Try getting an i5-4590 for EUR 190. https://www.amazon.es/Intel-1150-i5-4590-Procesador-3-3/dp/B00K5J22GG?ie=UTF8&tag=pcp02-21
It'll give you good Cities: Skylines performance.
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742922
Just now, Energycore said:
That's pretty good.
I live in a place where even that 190 could cost like 220. And i'm very poor. And i'll maybe not be creating that super populative city.
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742926
Gotcha. I found I could keep playing as my city grew if I turned down the settings, should be no problem.
In Europe, look for an XFX TS power supply. Those are usually great deals (get the cheapest, sohuldn't be more than 50).
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742930
Woah, the cheapest SeaSonic power supply is 68 euros here. But there's (bad) power supplies for 25 euros, though. Is EuroTech good?
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742939
Don't use bad ones, they'll kill your other components!
Where are you shopping? I can help out finding a good deal.
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742945
Where i'm shopping (cheapest parts around the entire island lol, 22% is IVA.) is here: http://www.coolmatica.pt/loja/
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742958
The only power supply that doesn't immediately concern me is the one from seasonic. :(
Can you get products shipped from Amazon.es? https://www.amazon.es/XFX-P1-430S-XXB9-unidad-funte-alimentaci%C3%B3n/dp/B00O3JHESA/ref=sr_1_2?s=computers&ie=UTF8&qid=1463230039&sr=1-2&keywords=xfx+ts
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742977
It's 4 euros cheaper, and yet the only drawback is that IT'S SPANISH and i have to wait 6-10 days. But why not?
https://linustechtips.com/topic/595778-my-current-build/#findComment-7742990
I mean, 4 euros is 4 euros :P
Back when I was in Galicia, I could buy about 1 and a half Coca Colas with those.
Lol
Computer Specs:
https://linustechtips.com/topic/595778-my-current-build/#findComment-7743326
