I have a 1500$ budget, but Im looking to spend 700$ on mods/peripheals/monitor. Can you help me to figure out a pc that could run cs:go 300+ fps on max settings and gta v on max at around 60?
Based on this build please, as I have bought these components already. http://pcpartpicker.com/p/Tt3Bgs
https://linustechtips.com/topic/595335-800-csgo-machine/
I would wait for the new gtx 10X0, or the AMD equivalent, they can apparantly get 200 FPS in the new doom, so you will atleast be CPU bound then
Prices on old cards will probably also go down, and its only a few weeks to wait
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/595335-800-csgo-machine/#findComment-7738103
1 minute ago, JPotze said:
and why would you want 300+ fps on cs:go anyways?
Lower mouse latency, because the monitor doesnt have to wait for new frames as long as for example 60 FPS or 200FPS
And no, G-sync isnt a solution to this problem, but comes pretty close to solving it by syncronicing the frames to the monitor almost perfectly
https://linustechtips.com/topic/595335-800-csgo-machine/#findComment-7738154
haha whatever you think is best for you my friend.
https://linustechtips.com/topic/595335-800-csgo-machine/#findComment-7738156
Is there someone who doesnt think more FPS is better than less FPS in games?
https://linustechtips.com/topic/595335-800-csgo-machine/#findComment-7738248
