Help! got a new chassis today and moved my build over. My computer was functioning completely normally but now every time I turn it on it shuts off after a few seconds, sometimes a little longer.
I'm using all the same gear I was using before just in the new chassis, I reset CMOS no change.
and yes I double checked the power and reset buttons are working fine.
edit: I checked each stick of RAM seperatly aswell
second edit: was able to make it to BIOS before it turned off, my voltages are fine too
https://linustechtips.com/topic/595265-help/
Are any wires touching the case? Something might be shorting the board. Take everything out and put it back together. get your cables in order and see if it works.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/595265-help/#findComment-7737472
Done and same result
Side note: beep code is normal
take out the GPU?
https://linustechtips.com/topic/595265-help/#findComment-7737491
no onboard graphics.
well you are just having a bad day today then arent you.
https://linustechtips.com/topic/595265-help/#findComment-7737499
