so as my CPU temperatures are getting high, i think it would be a good idea to by a AIO water cooler so i can lower the temperature and overclock my CPU.   so i have done some research and from what i can see this is the best AIO WC  https://www.amazon.co.uk/gp/product/B00N93KG4A/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE  and also i was looking at this https://www.amazon.co.uk/Corsair-CW-9060020-WW-Extreme-Performance-Liquid/dp/B010NS1LVA/ref=sr_1_1?s=computers&ie=UTF8&qid=1463072396&sr=1-1&keywords=corsair+water+cooling    not sure if they are as good as they say they are, or if there is a better solution at there.
Budget of £100
My PC: http://uk.pcpartpicker.com/p/TcQhD3
Thanks Cameron
https://linustechtips.com/topic/595023-need-a-water-cooler/
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734648
h110i GTX or kraken X61 are the good ones
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734662
1 minute ago, Julian5 said:
Thanks
any recommendations on thermal paste
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734663
Why the thermal paste? It comes with pre-applied paste and it is actually really nice
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734664
Saw a couple reviews saying thermal paste was not good, Always good to have extra anyways.
Elemental
Laptops
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734679
2 minutes ago, Nacho Marco Segui said:
The Corsair water cooler is better, since it has a higher radiator to dissipate the heat. But the fans are shit, i had it, and I had to create a custom fan curve, they are loud.
so i would need to get new fans if i brought this
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734680
Get noctua fans and MX-2 Thermal paste
Elemental
Laptops
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734685
No, the paste is good, do you think that they would risk their product by putting cheap paste?
And to op, you don't need new fans, they work great, the stock fan profile is too aggressive IMO.
Anyways, I would get the Kraken X61 if budget allows it.
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734694
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734704
Thats what I read from reviews anyways, heres a link to the kracken https://www.nzxt.com/products/kraken-x61
Elemental
Laptops
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734707
1 minute ago, FilipSebik said:
can you only get them in that brown as they look so ugly LOL
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734714
With LED strips they don't look like poop but you can still get those for the same price
http://www.amazon.com/Fractal-Design-Venturi-HP-14-FD-FAN-VENT-HP14-PWM-BK/dp/B00VYEI17U/ref=sr_1_1?ie=UTF8&qid=1463073711&sr=8-1&keywords=venturi+hp-14+pwm
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734721
What, why did you link the kraken? xD
A couple members suggested the kracken and if he has 40 extra $ he should get it.
Elemental
Laptops
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734724
so do i need new fans for that too @Julian5
Already has fans.
Elemental
Laptops
https://linustechtips.com/topic/595023-need-a-water-cooler/#findComment-7734730
