RAID array on same controller as boot drive
14 hours ago, Windows7ge said:~snip~
Both RAID types involve risks and issues either due to hardware failure or due to software changes so you would have to choose which one would bother you less and which has a lower chance of happening (swapping motherboard/hardware failure or reinstalling the OS).
If you are reinstalling the same OS it SHOULD see the same array instead of separate disks as it uses the same drivers to handle the RAID. Hardware RAIDs are presented to the OS as a single drive so they are not affected by changes of the OS, but software RAIDs are controlled by the OS's drivers. Using the same OS theoretically uses the same drivers and (again putting the word in capital letters) SHOULD see the same array, but that's a big "should".
Either way, a complete backup would grant you safety against any potential problems. ![]()
Captain_WD.
