Will Zalman CNPS9900 fit on ASUS Z170-A ATX LGA1151?
Solved by Naeaes,
Sure. The mounting is the same as it's been since LGA1156, the distance to the closest RAM is the same and DDR4 isn't any taller than DDR3.
EzioWar ·
Posted in Programs, Apps and Websites5 -
sogandolma ·
Posted in Cooling0 -
7
jordanbuilds1 ·
Posted in CPUs, Motherboards, and Memory5 -
12
1
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
