In the next few weeks I'm going to build a new gaming pc with a budget of about $1800 and I need help picking parts the games I play alot are wow league ffxiv skyrim fallout I would like to play these on max settings sometime do some streaming and a bit of video editing I only need the tower and I going to reuse my hdd from old system
this is what i have picked out from various sources
http://pcpartpicker.com/p/XDG2Q7
I didn't put the graphic card I was going to get a gtx 980ti but then the 1080 is coming out around the same price so I'm thinking of getting that
https://linustechtips.com/topic/594659-need-help-with-final-gaming-computer-build/
I'd go 6700k instead of 5820k for a bit better gaming performance
When rendering, the 5820k will be faster but will you actually be rendering videos very often? Or maybe just one or two a week?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
1 hour ago, Dreadrot said:
What kind of display do you have? As you'd save cash on a free-sync display vs g-sync
same relative performance for less
PCPartPicker part list: http://pcpartpicker.com/p/Vzv2Q7
Price breakdown by merchant: http://pcpartpicker.com/p/Vzv2Q7/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: ASRock X99 Extreme4/3.1 ATX LGA2011-3 Motherboard  ($219.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($57.99 @ Newegg)
Storage: Mushkin ECO3 480GB 2.5" Solid State Drive  ($119.99 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Total: $947.43
Generated by PCPartPicker 2016-05-11 19:16 EDT-0400
