I'm trying to make the second loop go back to the first one. I'm not sure why my code didn't work but do you guys have any suggestions?
import java.util.Scanner;
public class HW05P05 {
	public static void main(String[] args) {
		Scanner input = new Scanner(System.in);
	int x = 0;
	int choice;
	do{
		System.out.println("Binary Number Converter");
		System.out.println("1. Convert Binary to Decimal");
		System.out.println("2. Convert Decimal to Binary");
		System.out.println("3. Exit the Program");
		System.out.print("Enter your choice (1-3): ");
		choice = input.nextInt();
		if (choice > 3 || choice < 1){
			System.out.println("");
			System.out.println("Sorry that's not an option");
			x--;
		else if (choice == 3){
			System.out.println("Bye!");
			System.exit(0);
		x++;
	}while(x == 0 || choice > 3 || choice < 1);
	String empty = input.nextLine();
	double sum = 0;
	int i;
	do{
		System.out.println("Enter Binary: ");
		String binary = input.nextLine();
		int length = binary.length();
		int length2 = binary.length();
		for (i = 0; i < length; i++){
			char check = binary.charAt(i);
			if (check == '1'){
				sum = sum + Math.pow(2,length-1-i);
		System.out.printf("Decimal: %.0f", sum);
		x--;
	}while(x == 1);
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/594610-help-with-java-loops/
	int x = 0;
	int choice;
	do{
			x--;
			System.exit(0);
		x++;
	double sum = 0;
	int i;
	do{
			if (check == '1'){
		x--;
	}while(x == 1);
Just to be clear, you want the second do-while loop to end up at the top of the first?
Just put them both inside a while loop.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/594610-help-with-java-loops/#findComment-7730128
yes.
I tried something like this
but it didn't work because the second time i try to access the binary -> decimal converter it gives me a 0. Instead of asking for a new binary input.
Quote
int x = 0;
int choice;
do{
x--;
System.exit(0);
x++;
int i;
do{
double sum = 0;
if (check == '1'){
x--;
do{
x--;
System.exit(0);
x++;
}while(choice == 1);
https://linustechtips.com/topic/594610-help-with-java-loops/#findComment-7730170
