So I've been trying to install Ubuntu on my custom rig and dual boot in with W10. When I boot into the USB that i can install Ubuntu with, it gives me a text based startup install screen as opposed to the GUI I've seen several times in install videos. It's just a black boot screen with an Ubuntu logo and a few lines that say "Try Ubuntu before installing" or "install ubuntu" and when I select any of these options, the screen lags a little and goes black and then my monitor displays a "no signal" image although my pc is still on.
Ive tried the same process on my laptop and the install USB worked how it should, with a GUI and everything, so i dont know whats wrong. I have an MSI mobo with a legacy bios if that helps.
thanks!
https://linustechtips.com/topic/594547-problems-installing-ubuntu-1404/
its not 32 but pc is it?
The odd thing is it working with the laptop, perhaps try a different usb port on the pc.
The only other thing I can think of is the gpu/drivers being an issue, try the mobo video out or using the integrated graphics if you can.
Does the issue occur with the live os/try before install or is it only with the install option?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
nope not 32bit. ive tried different ports and same thing. is the live os/try before installing thing something you do while in windows? i havent tried that if thats the case
also i have an FX 6300 so no integrated graphics
the live os is the option that says try before install, it runs from the thumb drive
                   _/ V\
    ______|   __/_/| |
