So, I have a machine sitting in a room with no display connected to it. It is controlled either by TeamViewer or VNC, while a KVM is being considered.
Problem is, if there is no screen connected to the GPU outputs, I can't get accelerated graphics to work and the resolutions I'm able to choose from aren't ideal (no 1080p, for example). Connecting a cable on it's own doesn't trick it.
Is there any kind of workaround for this? Or some kind of adapter that will trick the GPU into thinking a display is connected?
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/594462-force-hardware-acceleration-without-display/
Actually, I found an accelerator that will do just that - connect to the GPU and act as a display. Will probably give that a try until a KvM setup.
~ Specs bellow ~
yes there are little adapters that you can buy that simulate a screen, linus uses them too :D
(the little black plugs coming out of the gpus)
http://www.amazon.com/CompuLab-fit-Headless-Display-Emulator/dp/B00FLZXGJ6
I didn't realize Linus also used these :D Yep, found just the item you linked, but unfortunately won't ship here. I did find an alternative that will, though. Ordered :D
~ Specs bellow ~
