Need 4pin EPS to SATA or Molex??
Solved by W-L,
14 minutes ago, AMD Lover said:Okay, so I pulled out a stick of RAM to see what it was. Its got 4GB in the PC and it says it will support 8GB on Acers site. I pulled out the stick and it says GDDR3 but on Crucial it says that DDR3 will work. Did this random manufacturer that Acer used just stick a G in front of DDR3 or is it actually GDDR because its a SFF and has a Nvidia GPU on the motherboard itself.
For the power then I would recommend a sata splitter then since one of the 4+4 pins is occupied. As for the RAM it should be DDR3, GDDR would mean it means graphics memory which it's not on a motherboard.
