So I built my PC recently and everything seemed to be working fine until I finally tried to download my drivers. I realized that my Ethernet was not working and then discovered that the driver was not installed for it. So I went to my motherboard box and found that there was a disc for the motherboard driver but I do not have an optical drive in my PC. Is there any way I can get the drivers installed without purchasing an optical drive? Help and responses are GREATLY appreciated.
https://linustechtips.com/topic/594216-please-help/
1. Use the internet on a different computer to download the network driver to a usb stick
2. Use an optical drive on another computer to copy the network driver to a usb stick
3. Download the driver software on your phone, attach it to the computer via usb cable and install it from there (assuming you have a Windows or Android phone)
4. Buy a usb optical drive for 20 bucks
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/594216-please-help/#findComment-7725839
