Copying OS to a bigger drive okay?
vong
Hi,
I'm looking to upgrade my current 250gb ssd to a larger 750gb ssd for my OS. Would it be okay just to copy everything over then just switch the drives?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
clone dont just copy but yes, though it can have some issues. try it and if it fails do a fresh install as fixing it would be all but impossible.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[i7-7700k@5Ghz | MSI Z270 M7 | 16GB 3000 GEIL EVOX | STRIX ROG 1060 OC 6G | EVGA G2 650W | ROSEWILL B2 SPIRIT | SANDISK 256GB M2 | 4x 1TB Seagate Barracudas RAID 10 ]
[i3-4360 | mini-itx potato | 4gb DDR3-1600 | 8tb wd red | 250gb seagate| Debian 9 ]
[Dell Inspiron 15 5567]
Okie doke. Is there a program you can recommend?
if you can just do a fresh install, there can be issues with cloning an OS
i use minitools part wizard but there are more specialized ones, just google and pick
                   _/ V\
    ______|   __/_/| |
EASEUS Todo Backup or Macrium work well.
Used Macrium to clone the drive and everything is going well so far :)
