Lately I've got a lot of graphics problem like this in almost every game the
http://imageshack.us/photo/my-images/801/36d1.png/
I've never had problem like this before and the first time that i noticed them was in hawx but are realy evdent even in skyrim
Please can anyone help me on this ?
Rig: i7 4770k, R9 290 tri-x, 16gb Corsair Vengeance, Asus Z97 PRO, Corsair RM750, Carbide 300r, Cooler Master Hyper 212 evo, 120Gb samsung 840 evo, 2tb WD green
https://linustechtips.com/topic/59383-graphics-problem-everywhere-please-help/
What's your specs?
][ CPU: Phenom II x6 1045t @3,7GHz ][ GPU: GTX 660 2GB ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 8GB @1450Mhz CL9 DDR3 ][ PSU: Chieftec 500AB A ][ Case: SilentiumPC Regnum L50 ][ CPU Cooler: CoolerMaster Hyper 212 Evo & Arctic MX4 ][
I've got a laptop with an radeon hd 5470 with 512 mb gddr5 and i've tried to reinstall the driver but nothing
Now I've tried whitou the driver by using the windows generic drivers and it seems to work just fine almost smoother than the amd drivers, after this I've reinstalled the amd driver and suddenly the same problem occured again but this time during the installation he gave me an error whit the c++ 2010 redistributable x64
any idea ?
It happen always and i don't think it's the heat because i've just cleaned the heatsink and changed the thermal past, the drivers worked fine until now and I can't retriev an older version because this is the only one available on the hp site
please post what hp laptop you have and i can help you with the driver but have you tried reinstalling win and after what did it occour i mean it happend right after you installed new software
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
I have an pavilion dv6 3102sl and I would like to reformat it but I can't because my monitor is brocken and i use a secondary monitor with the vga but it doesn't display the bios
does it display the boot before the OS loads or does that also not display? if you can still see the post on the VGA you can install windows like that with format just press F8 or the button that is the Boot option on your laptop and then try till you get to the DVD :D
if i had to guess that glitch is often when you overclock to much or at lest that is when i started to see it. even on a Xbox 360 just before it RROD'ed so it may still be overheating for some reason make sure fan is working fine.
Needs Update
No the external dislay works only on windows I can't see anything before the windows login screen and about the heat I'm pretty sure that's not that the fan is spinning correctly and whit core temp it always stay below 80 -70 c°right now at idle only whit the browser open its at about 50 c°
