2 minutes ago, Gregrs said:
Title says it all, I just did a clean install of Windows 7 Professional because Windows 10 wasn't working out. I hit "check for updates" and it's been checking for updates for about 3 1/2 hours. Is there a way to fix this, or will it take a while?
Did you install all your drivers again before installing the updates?
This is a known bug with Windows 7. Try this:
Microsoft released a new Windows Update Client Update to fix the slow Update searching/Installation.
Installing and searching for updates is slow and high CPU usage occurs in Windows 7
https://support.microsoft.com/en-us/kb/3102810
Download:
32Bit: http://www.microsoft.com/downloads/details.aspx?FamilyId=fcd6bf5d-f004-4ca3-aa7e-1de462b91dd0
64Bit: http://www.microsoft.com/downloads/details.aspx?FamilyId=4fe566bd-31b1-4413-8c4c-412b52533669
Stop Windows Update service (this speeds up the setup of MSU updates and the useless steps from Moab are not required) and try this Windows Update Client Update and see if it speeds up the installation of Updates.
There is also a newer version from March 2016. Also stop WU service and try to install this update.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
Download:
Do you know by any chance how long it takes to find updates? It's been running for about 45 minutes - 1 hour or so, and it still says "searching for updates on this computer..."
Ya, that first "one" can take forever. The subsequent are a lot better.
Tips:
1 - Not SP1? Download and it install it first off
2 - go to microsoft downloads and install directly .Net 4.5 and 4.6
