Do I NEED a new case?
So I've been looking at upgrading my PC and I was just wondering if I should get a new case? I was looking at one, but I was wondering, do I really NEED one? I currently have a cooler master k350 (with a built in PSU, that I WILL replace). I was originally looking at the Corsair Spec Alpha, but to me, it just seems like more money for no reason
https://linustechtips.com/topic/593766-do-i-need-a-new-case/
I used that case, It works. You don't even ned a case to run a PC, up to you really.
https://linustechtips.com/topic/593766-do-i-need-a-new-case/#findComment-7721319
Like the other two people said, you don't even need a case. Hell if you really wanted a case on the cheap, you could probably build a perfectly fine case with Cardboard.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/593766-do-i-need-a-new-case/#findComment-7721390
Mastercase 5/ 5 Pro.
Cases are very important. As well as housing all the components, they are like the skin.
They give the PC's a final appearance, either a make or break for most.
It is always a good idea to invest in a great case that looks amazing, has lots of features, and is just all round great.
That's why I chose the mastercase 5 Pro for my build.
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/593766-do-i-need-a-new-case/#findComment-7721393
Honestly, if you like your case its fine.. You don't have to go through all the effort of changing all the components to the new pc.
But if you don't like the look of the case or the airflow, it might be smart to get that new case.
https://linustechtips.com/topic/593766-do-i-need-a-new-case/#findComment-7721408
