Hey,
I am going to upgrade my CPU to the i7 6700K, and therefore require a new mobo with the LGA1151 Socket.
My colour scheme is black and green and therefore I do not want a white motherboard like the Z170-A.
I have found this: https://www.amazon.co.uk/Gigabyte-G1-Sniper-Intel-B150-LGA1151/dp/B01DTL91JW/ref=sr_1_2?ie=UTF8&qid=1462827681&sr=8-2&keywords=G1.Sniper+B7
But I do not know it's OC potential and I do not wish to spend over £120
Any help would be greatly appreciated,
Smiffy
https://linustechtips.com/topic/593710-mobo-help/
You won't be able to overclock with that board. You need Z170 to overclock.
Gigabyte however does have a Z170 variant of that board.
https://www.overclockers.co.uk/gigabyte-ga-z170-sniper-intel-z170-socket-1151-ddr4-atx-motherboard-mb-537-gi.html
https://linustechtips.com/topic/593710-mobo-help/#findComment-7720615
Just now, Smiffy_ said:
Okay thank you
I believe this is the version you want
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/593710-mobo-help/#findComment-7720625
