Wireless Adapter
Go to solution Solved by Windows7ge,
26 minutes ago, DennisTechTips said:
I was looking to buy a wireless adapter and I was wondering if the "Asus PCE-AC56" or if the "TP-LINK N900" would be a better buy. If they have about the same performance I will probably pick up the Asus adapter just to match my red and black theme.
I'd grab the Asus PCE-AC56. Unless you transfer a lot of data over your local network in which case I'd go with wired your Wireless AP/ISP will be your bottleneck so you won't reach the full performance of either card anyways. Might as well go with the one that suits your aesthetic.
https://linustechtips.com/topic/593283-wireless-adapter/#findComment-7716212
