7 minutes ago, fred32xp said:
What would you get an i7 6700 or 6700k if the 6700k how much could you overclock it with a 212 evo
If you can afford the difference of a 6700k + z170 + cooler, while not sacrificing on other components (such as the GPU)... then I guess go for the K version.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/593257-i7-help/#findComment-7715861
The Intel i7-6700K would be a better choice in my opinion as the price difference isn't huge, but also as you can probably overclock it relatively well with the CM 212 Evo.
You'll probably only get a few hundred megahertz more though, so a better cooler like the Corsair H series or the NZXT X series would be preferable for better cooling and overclocking.
Diasporic Kurd
https://linustechtips.com/topic/593257-i7-help/#findComment-7715865
10 minutes ago, fred32xp said:
Now what i7 6700k or 4790k
Might as well go for the 6700k...
6 minutes ago, fred32xp said:
Or 5820k which is fastest and will play minecraft at 400fps 1080p at max settings
You don't need either to get 120 on minecraft.
https://linustechtips.com/topic/593257-i7-help/#findComment-7716027
I'm confused as to why you need such a high frame rate in the first place. If your monitor can only output say 60Hz, 60FPS is all you need.
https://linustechtips.com/topic/593257-i7-help/#findComment-7716083
6700k
6700k
14 minutes ago, partypanda64 said:
didn't they kill 6700 overclocking?
What? When?
This ^
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/593257-i7-help/#findComment-7716095
2 minutes ago, partypanda64 said:
non k 6700's
Ah, yes they did. They (intel I believe) killed overclocking of all non k CPUs not too long after the exploit was created.
2 minutes ago, fred32xp said:
So for multitasking which would be better
You won't notice any improvement from a 5820k over a 6700k
If you have cash burning a hole in your pocket.. it's up to you. But the 6700k will be slightly cheaper.
https://linustechtips.com/topic/593257-i7-help/#findComment-7716113
Define "kill". The only thing they did was force board partners to push Bios updates locking it. But the older Bios are still available out there without much effort.
But the multitude of issues associated with BCLK Ocing (even before Intel stepped in) are still there.
https://linustechtips.com/topic/593257-i7-help/#findComment-7716133
ok the the 6700k it isbut now how about a good cooler that can overclock plus (if you don't mind) can you state the overclocking potential of the cooler
Aim for a 240mm WC, or even a 280mm one if your case permits.
As far as OCing, it'll OC as much as you can squeeze out of your overall setup and test methodology allows (which is another way of saying no one can answer that question outside of yourself).
https://linustechtips.com/topic/593257-i7-help/#findComment-7716211
