You could try swapping out the front panel after you check the hd audio connector on the inside of the case or if it is too hard to swap out go for a 5 and a quarter inch bay front panel
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/59315-front-panel-audio-jack/#findComment-804685
Bogus. It's like the port is bent or something.. only reading when the 3.5'' jack is slightly pushed to the left. I'm not exactly sure how the wiring is done, but maybe it's just a bad wiring job? Guess no one would really know until I took the thing apart.
https://linustechtips.com/topic/59315-front-panel-audio-jack/#findComment-804738
Front panel audio is usually built poorly, though mine hasn't broken yet after a year of use.
You could always use the port on your motherboard.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/59315-front-panel-audio-jack/#findComment-804841
Antec 1100 victim over here...
My "sweet spot" is with the jack 1/3 connected facing downward.
I just use USB now...
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/59315-front-panel-audio-jack/#findComment-804958
