1 minute ago, Oshino Shinobu said:
For the same price, you can get a SanDisk SSD Plus or Crucial BX200 240GB drives. I'd go for one of those.
http://www.amazon.com/dp/B00S9Q9VS4/?tag=pcpapi-20
http://www.amazon.com/dp/B016JREGAC/?tag=pcpapi-20
Which would provide better performance?
https://linustechtips.com/topic/592938-need-help-picking-an-ssd/#findComment-7712921
4 minutes ago, EskilHR said:
How much does your games take up?
I typically only have the current game I'm playing installed, maybe 2-3. So not much.
2 minutes ago, Oshino Shinobu said:
The difference between them is negligible.
Thanks, that Crucial is now at the top of my list atm.
https://linustechtips.com/topic/592938-need-help-picking-an-ssd/#findComment-7712926
TLC NAND is the devil. I use "old" Micron M500s, 240GB, bought from Micro Center for $61 each (they're on Amazon for about that price) to keep MLC in the family. They're plenty fast for just about any gaming application, and given how cheap they are and how well they perform, I heartily recommend them.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/592938-need-help-picking-an-ssd/#findComment-7712931
