Why not spray it yourself
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/59260-help/#findComment-804011
Not sure if spraying them will be good.
Cover the threads.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/59260-help/#findComment-804024
Any normal spray paint should work right?
And for painting the top: 1271661-fractal-design-arc-midi-r2-monta
And the front
Would that be the same process?
Uh... I dont know.... Go to your local hardware store, and ask them what spray paint to use for brushed ally.
https://linustechtips.com/topic/59260-help/#findComment-804055
I meant painting the metal on the top. and the front.
Yep he was refering to the brushed aluminium which is the front. For each you probably just need a good primer and you should be fine. Just make sure you do light coats and spray evenly. If possible, bring the parts to your local hardware store and they can recommend a primer and paint that won't eat away at the material.
Preparation is the most important part, the more work you put into preparation, the better the final result will look. So whatever you don't want painted, tape up well.
After the primer you should be able to use a wide range of paints, enamel, etc.
For the screws, just tape up the threads and paint the tops or whichever part will be displayed.
https://linustechtips.com/topic/59260-help/#findComment-804074
Probably just need a good primer and you should be fine. Just make sure you do light coats and spray evenly.
Thanks, Will post when this build is finished.
I'm going for a black arc midi R2 with green highlights Screws, cables , lights etc.
I think the best way to paint the screws without painting my fingers is to put all the screws in a straight row in Styrofoam so they don't wiggle and fly out
https://linustechtips.com/topic/59260-help/#findComment-804093
