got a temporary power supply for now to power my pc. my power supply is Deepcool DE-500 for my mobo: 970A-DS3P, cpu: FX 8320, gpu: GTX 750 Ti
Deepcool DE-500 specs:
+3.3V = 16A
+5V = 16A
+12V = 25A
-12V = 0.5A
+5VSB = 2.5A
Rated Power = 350W
Peak Power = 500W
my GTX 750 Ti requires at least 400W and 20A. im worried because it says rated power only 350W
thoughts?
https://linustechtips.com/topic/591976-is-power-supply-enough/
it will work
a system with a 750ti uses about 250W max
but deepcool doesnt make very good quality PSUs so you should try to replace it with a seasonic or EVGA soon
https://linustechtips.com/topic/591976-is-power-supply-enough/#findComment-7702881
Just don't put everything under max load aka no aida64. Also, no OC on the GPU
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/591976-is-power-supply-enough/#findComment-7702882
+3.3V = 16A
+5V = 16A
+12V = 25A
-12V = 0.5A
+5VSB = 2.5A
Rated Power = 350W
Peak Power = 500W
thoughts?
yea, this is just temporary. tnx for the input
https://linustechtips.com/topic/591976-is-power-supply-enough/#findComment-7702900
I'd look into a better PSU. This one is fine for now but not in the long scheme of things
https://linustechtips.com/topic/591976-is-power-supply-enough/#findComment-7702932
