Hello everyone, I'm having a bit of a trouble with my laptop. So I installed forza 6 apex recently but it said that my graphic driver is not compatible. Then I find out that the game keep detecting my I GPU instead of my GTX950M because the i GPU is the default GPU. can someone help me how to turn fro  i gpu to NVidia gpu? thx
https://linustechtips.com/topic/591973-how-to-switch-it/
some laptops only use the gpu if they are connected to power.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/591973-how-to-switch-it/#findComment-7702866
I had the same error on my laptop, try updating your drivers.
https://linustechtips.com/topic/591973-how-to-switch-it/#findComment-7702982
Nvidia Optimus only enables the 950M when you put a 3D workload on the system
https://linustechtips.com/topic/591973-how-to-switch-it/#findComment-7703064
