HWMonitor Temps
Go to solution Solved by mrgooglegeek,
what cpu do you have?
While I was running a stress test, I noticed that HW Moniot showed that my CPU was had reached a max temp of 129 degrees Celsius and Core Temp showed a max temp of 46 degrees! Do you think that HW Monitor has a bug or is it right?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/591631-hwmonitor-temps/
BTW, I closed the program and reopened it and it again after a while it showed a temp of 129 degrees the third time I opened the temps were OK...
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698811
AMD FX-6100
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698833
Its just an issue with HWmonitor, dont worry about it. AMD CPU's dont always show correctly in hwmonitor, they don't measure temps in the same way. depending on your motherboard, you may be able to get software from the manufacturer (if its asus, AI suite has a good temp monitor)
Its automatic, just press this button!
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698845
THX!!!!! and I was so worried... SHould I just use CoreTemp?
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698855
You can never entirely outrule a software problem, even if its unlikely since to my knowledge HWMonitor is a rather reliable programm.
However I would just get some other programms that can read out temperatures and check what they show.
For example: aida64(has a trial version) or msi afterburner would be the next most commonly used apart of HWMonitor.
Another, maybe less knowen options would be: realtemp, speedfan or coretemp.
@Nord or quote me if you want me to reply back. I don't necessarily check back or subscribe to every topic.
Amdahls law > multicore CPU.
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698866
They don't always work on AMD...
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698879
Anyway... Thx guys!
https://linustechtips.com/topic/591631-hwmonitor-temps/#findComment-7698882
