 So my friend just picked up his R7 360, ran DDU and installed the GPU and drivers. Thing is, the Audio Device (speakers) isn't being picked up and the drivers are apparently borked - he's on Windows 7 and Windows update is also bricked for some reason. any idea why DDU would make the speakers not being recognized? Currently reinstalling 16.4.1 Crimson
https://linustechtips.com/topic/591192-audio-driverdevice-issues/
Can you see the speakers in device manager?
If so then rightclick it and press "update driver software", it has solved a lot of things for me, including broken touchpads because of some reason
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
Only USB audio device is present there
is the audio coming from HDMI on the GPU?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
try looking in "other devices" a lot of stuff end up there because of some reason
There is an "unknown device"
There is "AMD HD Audio Device" but disabling that didn't do shit - both front and rear audio jacks don't seem to change things
1 minute ago, noisebomb44 said:
maybe "update driver software" will work although i doubt it
Odd stuff - it's an HP workstation board with a Q8400, 6GB DDR2 and R7 360. Speakers worked with his 9600GT and 361.75 but DDU messed it up somehow?
Did you enter safe mode before while using DDU? Otherwise the drivers should be factory new
Edited by noisebomb44
rephrased it
look at the hardware ID and do a google search on it
see what device is it and the missing driver
did he ever install audio drivers before this happen?
Did you enter safe mode before using DDU? Otherwise it should be factory new
We did yes.
1 minute ago, Moonzy said:
did he install the right audio driver for his motherboard?
Erm, no idea what his board is but will check
We didn't install mobo drivers AFAIK
take a screenshot like this
google search the hardware ID
2 minutes ago, Moonzy said:
windows 7 doesnt include as much basic drivers as windows 10, so that might be it
Yeah, I believe only 8.1 and 10 auto-download the needed drivers
sorry the picture didnt appear
do a quick search and it will point to some obscure device name
Friend is running an errand, will check. Thanks
No luck. Installed the Audio drivers for the board - still no sound
The Unknown device is the camera
ok what is the model of the mobo?
It's from an HP XW4600 workstation
here is my suggestion
completely uninstall the driver for the audio
put a check on "delete the driver software for this device "
force the PC to check for hardware changes
it will flash for a while and the add new hardware notification will appear
report how it went
report how it went
More detailed steps please xD
sorry
you need to go to device manager
go to the audio device you find in the PC which is Realtek audio
right click on the device and select "Uninstall"
report how it went
