For some reason, on my PC, one of the front USB 3.0 ports just don't work. I swear I connected the USB 3 connector to the port on my mobo, but it doesn't work at all. It doesn't even give power to devices I plug into it. I'm using a Fractal Design Node 804, A Gigabyte B85M-D3H Micro ATX board, and an EVGA 750W power supply
Edited by Narigaur
https://linustechtips.com/topic/591054-front-usb-port-not-working/
  • 1 month later...
Make sure it's in there properly and that it's not in the wrong direction. Make sure to also check your USB drivers just in case. If none of those fix the problem then the cable might be defective and the best choice would be to send it back in for a replacement.
I'm a person, you're a person...Together, we are people.
Bob Ross is the greatest painter ever! Happy trees!
Specs:
Processor: i7 4790k @4.7ghz
Game destroyer: Msi GTX 970 4GD5 OC (Soon to be a 1080 or Titan)
Mobo: MSI Z97I AC mini ITX motherboard
Fridge: NZXT Kraken X31 120mm liquid cooler
Lambo: Samsung 850 EVO 120gb SSD
Honda Civic: Random Toshiba 2TB 7200rpm HDD
PSU: EVGA Supernova 650 g2 (Currently out for RMA)
Case: NZXT S340 Midtower PC case
I just said I got a warranty replacement from Fractal. I'm still using the Intel eXtensible USB 3.0 controller driver that comes with Windows 10.
  • 5 weeks later...
