I have been using the MSI Geforce GTS 450 for 2 years now, just simple games Counter-strike:Global Offensive, Battlefield 4 and some World of Warcraft.
The idle temps used to be like 30-35 , now its 45-50 Celsius However when under load it's still in 77-83 range like used to be!
To get atleast something more from this GPU i've overclocked it from
VOLTAGE 1012
CORE CLOCK 783
SHADER CLOCK 1566
MEMORY CLOCK 1804
To
VOLTAGE 1087
CORE CLOCK 1000
SHADER CLOCK 2000
MEMORY CLOCK 2100
Note as i said the temps used to be better with the same overclock!
I did clean the PC today with compressed air and put on some new thermal grease on the GPU.
The compound is
Cooler Master: IC Essential E1.
And yes i did even check it after tightening the screws and unscrewing them just to check if the grease has applied NORMALY and it did!
Capture.PNGI even keep the case sidepanel open just so the components can breath some more!
https://linustechtips.com/topic/589985-idle-temps-are-high/
Does your fan turn off when your card isn't under load? It might have been implemented in a driver update and as a result runs a bit hotter at idle.
That's what my 970 does (well, it's always run a bit warm at idle, but that's because the fans turn off)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/589985-idle-temps-are-high/#findComment-7679889
1 minute ago, MrToad said:
Nope, as you can see in the picture, the fan is running at 52%!
I don't really trust that slider, find the graph that shows gpu fan speed
https://linustechtips.com/topic/589985-idle-temps-are-high/#findComment-7679898
it's not overheating when under load and a little rise in idle temps aren't likely to do it any harm, but long term overclocking to what appears to be extreme amounts can cause extra wear and tear, and might have a part to play in that. Unless you mean it was 30-35 before cleaning and 45-50 after, in which case I'd suspect ambient temps and the gpu fan curve really liking 77-83 under load
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/589985-idle-temps-are-high/#findComment-7680052
