I'm trying to connect an xbox 360 controller to my PC, i have some cheap wireless receiver i got off of amazon. Whenever I plug it in, it says that the drivers were not successfully installed. I've tried to manually download the driver off of the microsoft website, but when I do that it finishes installing and it gives me an error message saying that "This software version is already stalled on this system. To re-install this software, you must remove it first, and then run Setup again from the installation media. For information about removing a program, see Windows Help." even though, when I try to manually assign the drivers from the device properties of the unknown device, Xbox 360 Wireless Receiver is not listed as one of the available drivers.
hey man I'll help you out. right click on computer, choose manage (or get to device manager in some other way) choose device manager.
1. scroll to the unknown device
2. right click and choose update driver software
3. browse computer for driver software
4. let me choose from a list of device drivers on my computer
5. scroll to the bottom and choose xbox 360 peripherals
6. choose xbox 360 gaming receiver
7. Profit.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
it will always be there if you do the steps correctly I can even get to the option of choosing xbox 360 receiver as my phone's driver if I wish but it'll fail to install though.
pm me if you want me to try and help over teamviewer or something similar you want to use maybe? you can always remove it afterward if you're afraid I'll do something.
