That really just comes down to which one is on sale and whether or not you care for a little bit of bling like Corsair GS that has a led inside the psu
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
https://linustechtips.com/topic/5895-build-planning-help-please/#findComment-65792
Depends really on what your budget is. For about $100 you can get a Silverstone Strider Plus which is 100% modular.
Aside from that, I wouldn't bother with a WD Black. For $50 less you can get a Seagate Barracuda with near identical performance.
What's your overall budget for this, what is your aim and do you need perihperals including an OS and monitors?
https://linustechtips.com/topic/5895-build-planning-help-please/#findComment-65795
  • 2 weeks later...
