So the other day I upgraded the motherboard on my computer and re-installed windows 10 pro 64 bit and now I cant play games, like for example Civilization V opens up the menu to choose a load option I choose any option it just closes and does nothing. I have tried to contact microsoft support, but they don't help me they just try to sell me $150 worth of premium support.
Specs: AMD FX 8320
Gigabyte 970FXA UD3 R5 (New Mobo)
Gigabyte Radeon R9 270X
The old motherboard was a MSI 970a SLI Krait Edition
https://linustechtips.com/topic/589331-games-using-directx-wont-work-plz-help/
1 minute ago, Photogenic said:
Actually I have uninstalled and re-installed multiple times
from amd's website? did you get the correct drivers?
how bout motherboard drivers?
-sigh- feeling like I'm being too negative lately
Yep directly from the amd site, and I have done the same with the motherboard drivers
win key + r -> type "dxdiag" and press enter
under display tabs see whats the notes
DirectX 12
hmm...
download Display Driver Uninstaller and this driver
then run DDU to uninstall your current gpu driver and install the driver i linked, see if this fixes the issue
It didn't work. I do sometimes get bluescreens, the most recent one said driver_corrupted_expool
check device manager to see if there are any missing drivers
2 minutes ago, Photogenic said:
100% Shire I have re downloaded everything multiple times and it still doesn't work.
try running your games with different compatibility?
right click game.exe -> properties -> compatibility -> change it to windows 7 or something
or try running the game as administrator
both dont work, even weirder its not just that game CSGO starts installing gets to 100% and just stops doesn't actually install
what do you mean doesnt install? o.O
