Hello,
   I have bee having some CPU overheating problems. I was a woss and bought a pre-built system http://www.amazon.com/dp/B00GFG1B1A/ref=twister_B018ATTANK?_encoding=UTF8&psc=1 , and its has been having overheating issues. I have cleaned my PC extensively, and its still crashes in very light games like TF2, CSGO, and Payday. I live in a hotter area without AC, so I think that is the problem, and also the fans are in poor places, like a front fan the is blocked by a hard drive bay, and and a side fan. Should I put a intake fan on top and a outtake in the back?
https://linustechtips.com/topic/589265-cpu-overheating/
Many cases have fans that are blocked by hard drive bays. I don't necessarily think that's the issue. What are your ambient temperatures and have you checked the CPU cooler at all? Including thermal compound and the mount of the cooler.
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672686
3 hours ago, 115333_1454180247 said:
Hello,
Is the cooler in this picture the actual cooler that is installed on your CPU?
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672694
Is there an open fan mount in the front with no obstructions? If so, just intake front, outtake back. If not, just put that side fan in the back, it will relieve the CPU cooler of hot air.
Remount your cooler if you can.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672696
it may be an issue of running what looks like a 92mm stock cooler on a 125W cpu. you may need a better heatsink if nothing else works
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672701
I have not taken off the CPU cooler, but I have dusted it well. As for the CPU temps. last time I recorded them was about 80 degrees F in a game of TF2.
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672703
You said you were in a hot location without AC.  If you had to take a guess, what would you say the room temperatures are?
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672710
I hope you mean Celsius there.
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672722
2 minutes ago, 115333_1454180247 said:
If I where to add a fan in the back as an outtake, would it help? Also I was looking into upgrading my CPU cooler.
Do you have an exhaust fan currently?
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672734
Sure it would.  If you have fresh air coming in through the front and exiting the rear, it will help, but if your room is really that hot, your temps aren't necessarily too far out of line.
Good point, otherwise there's no more need to post because he doing great!  :D:D
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672736
adding another fan wouldnt help temps if your cpu cooler cant keep up with the cpu
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672741
I am moving to a cooler place soon hopefully it helps, I would say my house is 75 to 80 degrees F
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672748
Have you tried checking your temps with the side door removed?  You could use a regular house fan to blow cool air into the case with the door off just to see if CPU temps improve.  If you pull the door off and temps improve on the CPU, you'll definitely need to pursue that rear fan installation and possibly more.  If they don't improve, your CPU cooler is more than likely not up to the task.
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672761
80 C in a 80 F ambient?
I ran the stock cooler on the 8320 in an 85-90 F room maxing out @ 70 C for a couple months.
If you have spare thermal paste. I would try resetting the cooler. It might have the default pre-applied paste on it.
If you could measure how much space you have from the motherboard tray to the side panel? Based on pictures it looks to be somewhere between 150-160mm. Your cooler selection might be narrowed by that case.
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672767
51 minutes ago, 115333_1454180247 said:
Hello,
Yes I would roccmend first trying that, if you still have issues trying replacing your cooler and buying a new one for around $30 you can get a cooler master hyper 212 and for couple bucks some good thermal paste then it's simple unplug and remove old cooler. rub off and replace thermal paste then apply new cooler and plug it in once you that with at least decent case air circulations and you'll be hunky dorky
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/589265-cpu-overheating/#findComment-7672866
