So I have this board: http://www.amazon.com/Intel-BLKD33217GKE-NUC-Board-D33217GKE/dp/B0093LINYC
And I'm going to 3D print an I/O plate for some extra usb ports, audio, and a power button. As inexperienced as I am I have no idea if the used stuff I found works.
http://www.stuartconnections.com/en/i-o-panels/785-Dell-PV122T-8-Inch-6Pin-Power-Button-2-LED-Cable-9R784.html
http://www.stuartconnections.com/en/i-o-panels/1635-Dell-Inspiron-530-531-Vostro-200-400-USB-Audio-Front-IO-Panel-XW931.html
Those are the I/O things I found... just looking for some else to tell me if it is compatible.
Thank you ;)
https://linustechtips.com/topic/588781-io-help/
Thank you ;)
they are.
just make sure that theres enough ports for them physically
https://linustechtips.com/topic/588781-io-help/#findComment-7667615
