Hello to all PC Enthusiast,
I need your help!
Help me build this beast with $2000
http://pcpartpicker.com/p/N4VTbv
Thing that you can change :
  • Cpu Cooler
  • SSD
  • Hard Drive
  • Video Card ( GTX 980 ti only ) *didn't choose because don't know which one to buy
  • Power Supply
Note* Ignore the monitor ( It's an extra to make it triple monitor setup )
IMPORTANT!
I prefer it to be Amazon price since I'm not from US
                                        My Most Loyal PC EVER!!
                                          9 years and still going.
CPU : Intel Core 2 Duo E4500          //         Mobo : ASrock ConRoe 1333-D667
RAM : 4 GB  // GPU : None... // Hard Drive : 2x 500GB // Case : Trendsonic idk.
PSU : idk, idc.                               //          Monitor : BenQ E900W
https://linustechtips.com/topic/588104-2000-x99-build-help/
I need your help!
  • Cpu Cooler
  • SSD
  • Hard Drive
  • Power Supply
IMPORTANT!
If your not in US why order from US Amazon? They´ll charge you border fees most likely.
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659307
Your build looks good. But if you're getting a 980ti, you should consider a 1440 or 4k monitor.
Otherwise the 980ti is kind of an overkill. You really should wait till the Pascal line drops, too.
As for the 980ti model, they are all solid models. Just get a dual 8 pin model for more power/oc.
I have a preference for MSI cards but that's just me.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659308
Everything on that list looks to be good. I'm not familiar with silverstone AIOs though so that's the only part I would possibly change. Not sure where you're from but Pascal is supposedly dropping soon and maybe your market will get it sooner rather than later.
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659322
I need your help!
  • Cpu Cooler
  • SSD
  • Hard Drive
  • Power Supply
IMPORTANT!
For the 980ti, go with the Gigabyte Xtreme Gaming OC edition
''IMPORTANT!
I prefer it to be Amazon price since I'm not from US''
Why don't you buy from Newegg.ca?
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659336
I need your help!
  • Cpu Cooler
  • SSD
  • Hard Drive
  • Power Supply
IMPORTANT!
Wait for polaris/pascal GPU's don't buy the 980 ti yet
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659348
I told you to ignore the monitor -_- ,
that monitor gonna be my third monitor,
i got a 4k monitor already
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659467
Oh snap, totally my mistake.
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659475
''IMPORTANT!
not from canada either,
my country charge too much on computer part because of tax,
that's why i choose amazon.
at my country the gtx 980 ti cost nearly $800 min
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659476
its ok xD
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659481
 but we don't know about the price yet right?
or is it because the price of 980 ti will drop a bit?
https://linustechtips.com/topic/588104-2000-x99-build-help/#findComment-7659496
