Invisible folder won't stay invisible
Solved by EliminatingAngels,
23 minutes ago, DarkestDiamond said:it's lighter, but it's still there (I have show hidden folders on)
Then I don't have any ideas left. You can try clearing your icon and thumbnail cache as well as checking your shortcut arrow overlays.
Refer to these links
http://www.sevenforums.com/customization/168221-transparent-icon-black.html
https://windowsforum.com/threads/windows-7-custom-icons-problem-black-squares.69706/
Good luck
