Unplugging GPU power while pc is on?
Go to solution Solved by Boobies Sprinkle,
Kamikaze.
I just had a wild idea, what if i unplugged the 6 pin connector on my GTX 970 while the system was running? not stress testing or anything but at idle. Would the pc just flat out turn off or will the system run fine until it realizes there is no power to the GPU? or will it run idle forever? i know this is a very stupid question but i don't wanna brick my GTX 970 while trying to figure out what will happen xD
So my question to you guys is do you know what would happen?
Thanks in advance :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/587887-unplugging-gpu-power-while-pc-is-on/
Don't do it.
I doubt it will cause any damage, but it's possible.
If I had to guess, your system would run fine until your GPU drew too much power, then it would either restart the card or trigger something in the PSU to turn off the system.
But I might be wrong. Like I said, don't do it if you value your card.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
2 minutes ago, HPWebcamAble said:
Don't do it.
Yea i luv ma 970, it would make sense if it would still run fine at idle as the traces on the mobo can supply like 80 watts to the card. And there are some cards that have no PCI-e connectors so ye.
3 minutes ago, Moonzy said:
system crash
possible gpu driver corrupt
possible hardware damage
possibly the dumbest idea ive seen today `-`
It would be funny to see what would happen tho xD maybe i have drank too much coffee today...
4 minutes ago, Zenedge said:
your system would probably crash
also, why would you think of doing something like that?
I just randomly thought of it while i was just looking at MSI afterburner xD
Yes, if blowing up a $300 piece of hardware is something you find funny.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
meh, i can't blame you, i once removed 1 ramstick while my system was running. it obviously crashed
some questions in life are so dumb, but we srsly want answers. haha
There is no such thing as a bad PC, there are only BETTER PCs
Yea i had an old dell where i just messed around with it. I took the ram out while it was running. The system didn't crash it actually produced nice green and red lines on the screen. And the longer i did it the cooler it got. Btw the ram didn't work after that xD. I also took the CPU out which turned off the system immediately. Seriously don't ask lol.
I've actually been wondering if it's possible to hot swap SATA storage devices.
Or SATA optical drives.
This one time my computer wouldn't POST and I took it out to check and then I realized I hadn't connected the PCI-E power cables into the GPU. I seriously thought the GPU was dead D=
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
There should be an entire workshop episode where they unplug different components with the PC running and see what happens
  • 4 years later...
I did this by mistake and now the Fans turn on but I have no pictures and was working fine just before I did that
