4 minutes ago, Slate :P said:
I plan on streaming PC games like CSGO, Rainbox 6 siege, H1Z1. Looking to only spend around $800-$1000, Is an i5 4690k good enough for what im looking to do? If not What should i get
Do you have the i5-4690K with you already?
Also your location please?
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
Alright. Here is what I recommend you should get. You're playing on 1080p, right?
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($301.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($36.99 @ Micro Center)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($317.00 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($73.77 @ Amazon)
Total: $864.62
Generated by PCPartPicker 2016-04-26 02:48 EDT-0400
Quote
i'd consider -generally- an i5 4460 to be the bare minimum for delivering a quality stream, if you can get a decent OC on that 4690K it certainly wouldnt be bad at all.
something to take in mind is the amount of threads your games of choice use.
example: CS:GO uses two threads, so you technically only have two threads that can be fully utilized for livestreaming.
i'd recommend something like quicksync or nvenc but from my experience both arent quite as good as x264 encoding, although my testing is a bit dated at this point.
Total: $864.62
all the yes to this one. i'd try to squeeze in a nice tower cooler for quiet operation, and an SSD tho. (and *please* up that to a 2TB barracuda, the difference is like $20)
Total: $864.62
Ok thanks.
Could i substitute this GPU? http://www.evga.com/Products/Product.aspx?pn=04G-P4-2977-RX  also why is this version of the card so much cheaper than the other versions
i wouldnt be able to tell you, evga is mindlessly expensive on this side of the pond.
Get an SSD along side the HDD. Get the 850 EVO
59 minutes ago, Slate :P said:
Ok thanks.
Why I don't recommend a GTX 970 over an R9 390:
Slightly worse DX11 performance
Significantly worse DX12 performance
Half the VRAM capacity, and even that is segmented into fast and slow portions.
And I have no clue why. Even when navigating their site normally, I can't find the part you linked.
http://www.evga.com/Products/ProductList.aspx?type=0&family=GeForce+900+Series+Family&chipset=GTX+970
Quote
