Hello these are my parts,
https://www.ekwb.com/shop/ek-supremacy-evo-nickel CPU Block
http://www.performance-pcs.com/d5-photon-270-reservoir-pump-combo.html#Additional-Information Res
https://www.ekwb.com/shop/ek-hd-petg-tube-10-12mm-500mm-2pcs Tubing
https://www.ekwb.com/shop/ek-hdc-fitting-12mm-g1-4-black-4258 Fittings
Can I please get a link to a Valve, Splitter and Fittings to connect the valve up to my loop. I would also like to be able to connect soft tubing to the valve to drain it.
Thanks.
https://linustechtips.com/topic/587378-valve-help/
https://linustechtips.com/topic/587378-valve-help/#findComment-7651566
7 minutes ago, W-L said:
Alright, And when its not in use do I need a cover for it?
https://linustechtips.com/topic/587378-valve-help/#findComment-7651593
volvo pls fix
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/587378-valve-help/#findComment-7651641
