9 minutes ago, edwar5jm said:
Spent a long time looking at the parts list
want to check to get any other opinions or suggestions
http://pcpartpicker.com/p/tHsPyc
I question the choice of CPU cooler (Cryorig C7 is better IMO) but other than that looks gr8.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Just now, edwar5jm said:
thanks. ill give it a look.
new to building a pc so any preferences are appreciated
I second what hackentosher said...I have not seen many people happy with the blackwidow...also id definitely get a cheaper Windows key...just a question, will you be overclocking? many people get an unlocked chip and a beefy cooler when they're never going to overclock, so you might be able to save some money there..
If you want my thoughts about storage, i agree wholeheartedly about the choice of the SSD but everyone talks about Seagate like its the Titanic....never had a problem with it myself but just trying to help you out here.
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
3 minutes ago, edwar5jm said:
no i dont plan on overclocking
You can save a few bucks by getting a 6600 and an h170 board, but if you go with what you have right now, you can get free performance by overclocking your chip.
For keyboards, look into Cooler Master keyboards. I know, sounds weird that the fan company makes keyboards, but they're REALLY good keyboards.
ASU
1 hour ago, edwar5jm said:
thanks for all the advice!
Id say it looks good and sounds good and im happy
http://pcpartpicker.com/p/fXB7D3
Heads up, it´s the H7 that´s better, not the C7.
Which one is the low profile?
Solitaire.
C7.
I prefer the C7 for looks, and both are adequate coolers.
Solitaire.
Tesseract could be a wrong choice of case , hope if you can stretch budget , then change it.S 340 was a solid choice
