I purchased ''GIGABYTE GA-965GM-S2 (rev.2.0)'' and on that motherboard was used Pentium 4 CPU, but I have Q8400 and when I put the CPU on socket and turn on my pc everything works only my display won't turn on. I get same processor and try It and it work everything perfect, can anyone help/give me any suggestions how to update BIOS or whatever to be able to run Q8400?.
https://linustechtips.com/topic/587175-need-help-for-motherboard/
You mean when you try the same CPU on another motherboard it works fine?
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
So you tried a different processor? Then It worked.
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
 Most likely a bad processor. Do you have another working motherboard to try the processor in?
My PC:
CPU: Intel i7 8700k
no no I put Pentium 4 on the same motherboard and it works but when I put Quad core Q8400 It is not giving me display.
Its probably the processors fault
Wiggle it around a little bit.
To check if it is dead or not,
Remove the heatsink and power on the system . Place your finger on the lid and see if it gets warm. If it does, it works.
Yes it is hot. But do I need bios update or something like that ? or i need to flash BIOS ?
